January 11, 2019 at 10:54 am
yannick.douard
SubscriberI modified the name of all material in my library (in French). I create a copy of a material and edit the property. When I right clic on a surface of an object, I can't view the panel with materiel property. I can't apply new material. How to reset the library material module ? I can't apply power or temp on the selected faces of an objet -
January 11, 2019 at 11:57 am
Gaurav Sharma
SubscriberATOS
I am checking if there is an option to reset the library and will get back to you soon. Also, can you please mention what the error message in the attached picture reads?
January 11, 2019 at 12:07 pm
yannick.douard
SubscriberThe error message is :
An error occurred while downloading " Library material" '
January 14, 2019 at 7:38 am
Gaurav Sharma
SubscriberATOS
Delete the located at: %APPDATA%SpaceClaimDiscoveryMaterialLibrary
Launch a new session of DL and you can now see the material definitions have changed to default. I hope this resolves your concern.
Best Regards,
Gaurav
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3670
2540
1749
1226
580
