Error when making a remote call to participant Solution 1.
    • Zuz Kun
      Hello, I am preparing a bidirectional FSI analysis (Fluent + Mechanical) I got this error package:
      Update failed for the Solution component in System Coupling. The coupled update for system Fluent threw an exception. Update Solution Failed
      (DP 0) An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
      (DP 0) A solver failure occurred during the run in the Fluent system
      (DP 0) Error when making a remote call to participant Solution 1. Please do not save the project if you would like to recover to the last saved state.
      There is absolutely no more explanation in Solution Information. What could it be? I need help, I'm on a tight deadline.
    • RM
      Please refer to the fluent transcript file to know more about the issue. As error suggests solver failure occurred during the run in the Fluent system. Make changes in fluent setup to avoid that error.
      Hope this helps!
    • Zuz Kun
      The content of the transcript file is as follows:
      Transcript Start Time: 14:42:14, 30 Jun 2023 Central European Summer Time
      Current Directory: "D:\butterfly_files\dp0\FLU-6\Fluent"
      Build Time: May 27 2022 08:52:29 EDT
      Executable Path: C:/PROGRA~1/ANSYSI~1/v222/fluent/ntbin/win64/fluent.exe
      ID Hostname Core O.S. PID Vendor
      n0* DESKTOP-MLO6B2Q 1/16 Windows-x64 10556 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
      host DESKTOP-MLO6B2Q Windows-x64 14712 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
      MPI Option Selected: intel
      Selected system interconnect: default
      Cortex Process ID: 5296
      License Server Path: 1055@localhost
      (cx-gui-do cx-activate-item "MenuBar*FileMenu*Close Fluent")
      Performance Timer for 0 iterations on 1 compute node
         Average wall-clock time per iteration: 0.000 sec
         Global reductions per iteration: 0 ops
         Global reductions time per iteration: 0.000 sec (0.0%)
         Message count per iteration: 0 messages
         Data transfer per iteration: 0.000 MB
         LE solves per iteration: 0 solves
         LE wall-clock time per iteration: 0.000 sec (0.0%)
         LE global solves per iteration: 0 solves
         LE global wall-clock time per iteration: 0.000 sec (0.0%)
         LE global matrix maximum size: 0
         AMG cycles per iteration: 0.000 cycles
         Relaxation sweeps per iteration: 0 sweeps
         Relaxation exchanges per iteration: 0 exchanges
         LE early protections (stall) per iteration: 0.000 times
         LE early protections (divergence) per iteration: 0.000 times
         Total SVARS touched: 363
         Total wall-clock time: 0.000 sec
      Transcript Stop Time: 14:42:38, 30 Jun 2023 Central European Summer Time
      Total Transcript Time: 0 Minutes 24 Seconds.
      I still don't know what to do with it.
    • RM
      Could you please share the content of the system coupling log file as well as mechanical solution output file?
    • RM
      Before solving the two-way FSI make sure that individual participant works well. You can use representative load on system coupling boundary.
      Also refer to this tutorial Reed Valve FSI Co-Simulation with Partial Setup Export from Workbench (Fluent-Mechanical) (ansys.com) and see if the settings and boundary condition are correctly defined.
Viewing 4 reply threads
