Ansys Products
Ansys Products
Error when opening HFSS
    • Amal85
      How to solve when this error happen? This error message came out when using HFSS module. The OS using is Linux. Is there any advise?
    • tsiriaks
      I would recommend to use HFSS/AEDT outside of the Workbench unless you really need Workbench for some unique functionalities.n
    • Amal85
      Still need to use Workbench for the project and also has turned off security and firewall software but it does not work.nn
    • tsiriaks
      What version is this ?nIf you open up a blank Workbench session, then insert HFSS module and double click on Geometry cell, does it launch AEDT successfully ?n
    • Amal85
      When double click on Geometry in workbench, AEDT cannot be launched. When launched AEDT alone, it come out with error : feature has expired. flexnet error -147, -10. However, the license is still valid. The version using now is 2019.R3n
    • tsiriaks
      Please post screenshot of the complete error message when launching stand-alone AEDTnAlso, open up Client ANSLIC_ADMIN Utility and check license status, then post the output of it heren
    • Amal85
      Hi!n Thank you for your response. Finally we can open AEDT. This happen because of we used expired licenses key. After change to a new license key the software can be opened.nn
Viewing 6 reply threads
