February 15, 2022 at 3:26 am
zhxlin
SubscriberI tried to simulated the travel-wave electrodes which consist of gold and titanium. But when I add wave port, I cannot pass the validation. It show the following errors:
February 15, 2022 at 12:59 pmAnchal Singh
Ansys EmployeeFebruary 15, 2022 at 7:50 pmzhxlin
SubscriberHi Anchal
Thank you very much for the answer.
I tried the "Enable materal override" setting under HFSS design setting. But I still get the same error.
Actually, the electrodes "sig_gold" and "sig_ti" are one electrode. This elctrode are composed of two overlaying matals (shown as the right-side yellow and green parts in the following image, and the left-side yellow and green parts are the ground electrode). I added a waveport to the facet of this electrode (the two overlaying metals in the right side). It seems that the waveport of HFSS doesn't allow me to have the two metals touch. When I raise the top metal by a very small distance like 0.000001nm, the error disapears. But I think there will be some problems if I spilt the two metals. Do you think if it is fine to spilit two metals? or is there any solution for this?
I appreciate your help.
Best Zhixing
February 23, 2022 at 11:57 amAnchal Singh
Could you please share more screenshots of your model with the proper labeling of objects? This would help us to understand your problem in detail.
Could you please tell us how are you assigning wave port for your model?
Thanks
Anchal
- Maxwell, HFSS or Q3D?
- Error
2726
2146
1357
1150
462
