error when starting fluent
    • firsthero
      so i am trying to do a 2D fluent simulation i get this error
      Ansys.Fluent.Cortex.CortexCommandFailedException: An error occured in FLUENT while applying case and settings informatins.
         at Ansys.Fluent.Cortex.CortexCommunicator.SendMessage(String msg, String msgKey, String errorMessage, Boolean waitForReply)
         at Ansys.Fluent.FluentCommunicator.UpdateSetupInfo(Dictionary`2 info)
         at Ansys.Fluent.Data.SetupData.ReadCaseModelInfo(IFullContext context)
    • RK
      Similar discussion can be found in the following thread of the student community.
      https://studentcommunity.ansys.com/thread/an-error-occured-in-fluent-while-applying-case-and-settings-informations/
      Rahul
    • firsthero
      the fluent launcher the dimension is locked to 3D and cant be changed to 2D
    • firsthero
      i cant find the requirements for 2D models as he suggested, the thread doesnt have a conclusion
    • johntojo98
      I am not sure about this if your model is 3 D then it will be locked as 3D
      if u want it to be 2D then your geometry should be 2D
    • firsthero
      it is 2d
Viewing 5 reply threads
