Ansys Free Student Software
Error when trying to save project
    • rpalessio
      I get a fatal error message when I try to save any projects from Ansys, does not matter the module I am using. After the message the software crashes and stops working. According to the message, I have a problem with a debugger and the Just-in-Time configuration. I tried to use Visual Studio to fix the problem, but that did not work as well. Could someone please help with that?
    • George Karnos
      What does the error say? Can you post a screenshot?
      Could you please open a Windows command prompt and run the command "set" without quotes and send the full output?
      Is there an install.err file located under c:\Program files\Ansys Inc\Ansys Student
      If so, could you paste the contents of that file?
      I ask to paste contents as we are not permitted to open files.
