Kampus Merdeka
Kampus Merdeka
Error when uploading C++ code to Ansys Fluent
    • Maria Arrese
      This error appears when I tried to upload the C++ code.
      Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified.
      Error Object: #f
      Does anyone know how to solve it?
    • Nikhil Narale
      Which Version of Ansys are you using? Try updating to the latest version and use the built-in compiler in Fluent.
      Else, try compiling using an external compiler (Try VS). It worked for most of the users. Let me know if it works for you.
      Thanks,
      Nikhil
