March 22, 2022 at 9:36 am
Mak
SubscriberHi
I got a problem when conducting fluent case on HPC.
It keep showing some property that I never seen before.
March 22, 2022 at 11:18 amRob
Ansys EmployeeWhich version was the case written in, and which version of Fluent are you running on the HPC? The first warning is about a model not being available, and it's difficult to save a case with models that aren't compatible as you usually get an error trying to set it up. The rest of the problems look to be linked to a missing value/property but that could be a result of the missing model. What else is written into the first 67 lines of the transcript?
March 22, 2022 at 12:22 pmMak
SubscriberMarch 23, 2022 at 12:42 pmMak
SubscriberI know what's the problem
The super computer don't accept NASA-9-piecewise-polynominal to interpret constant pressure specific heat
March 24, 2022 at 4:17 pmRob
Ansys EmployeeThanks for updating. Fluent cases will often read into an older version of the code, but if you're using a model/setting the older version doesn't recognise then it'll flag a warning that interesting things are about to happen.
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
7592
4440
2953
1427
1322
