Error when using “Ideal-gas” for mixture density
    • yijecho
      Hi all,
      I am modeling a gas-porous solid reaction. When I used Volume-weighted-mixing-law for the mixture density, all the calculations went fine without any problems. But, when I switched it to Ideal-gas, the calculation stopped with a Floating point exception error. The residuals for the turbulence terms got increased with iterations. What would be solutions to this problem?
      Thank you,
      Yi Je
    • DrAmine
      Much more conservative settings can be helpful like using smaller time scales and coupled pseudo-transient if steady.
    • yijecho
      Thank you for your comment. I already used the coupled pseudo-transient setting. I have solved this problem by reducing the relaxation factor.
      I wonder the reason why the ideal-gas mixing law caused the problem compared to the volume-averaged mixing law. I think the pressure and temperature terms in its density equation might affect the species transport to make the model more complicated. Would it be possible?
      Best regards, Yije
    • DrAmine
      Because you have now a pressure dependency for the density making the whole thing a bit stiff. Please mark as "Is Solved"
Viewing 3 reply threads
