Error when Using surf elements (plane183) & surf 153
    • tnegem
      Hi Everyone,
      Does anyone understand why I obtain this error message "real constant 1 referenced by at least element types 1(plane183) and 2(surf153)"
      The keyoptions I am using for Plane183 is (Keyopt (3) = 3) and for the surf element surf153 is (keyopt (3) = 10), If i remove the real constant the simulation runs smoothly.
      Kind Regards,
      Taha
    • peteroznewman
      Hi Taha,
      Can you attach a Workbench Project Archive that shows this error?
      That would be easier for me than building a model to try to recreate the error.
      Also please say what version of ANSYS you are running: 18.2 or 19.0 or other.
      Kind regards,
    • tnegem
      IT is a APDL Script that I built, In workbench it works fine but in my APDL code something seems off
      I could create a db file if you would like and I am using Mech. APDL 18.1
    • peteroznewman
      Go ahead and create a file to attach. If it is not a .wbpz file, you will have to make a zip file of your db to attach to your post.
      I am not expert at APDL, but the error is coming from the solver, which is the same whether the model was built in APDL or Workbench Mechanical.
Viewing 3 reply threads
