Discovery Import
Discovery Import
Error while extracting a result in ANSYS AIM
    • ankush.choudhary
      After simulating the flow physics, when I tried to get the simulated result of the Mach contour, the following error popped up which I am attaching with this post. Kindly revert back with an answer to rectify this error.
      Thank you
    • Naresh Patre
      Hello Ankush
      I don't remember seeing this error before. I tried plotting a contour plot of Mach number on a plane and didn't encounter any such issue. Did you try deleting the result object and create a new one? Also, are you getting same error for other result objects like pressure contour or velocity contour, etc.?
      Can you try closing the project, then perform the following steps:
      1. Clear all data from %temp% folder
      2. Go to ~AppDataRoamingAnsys folder and rename folder v195 to v195_old
      Once done, please open the project and recreate the result object. Let me know if this helps or not.
    • ankush.choudhary
      Hello Naresh Patre
      Thanks for your reply. I got the solution.
    • Naresh Patre
      Hello Ankush
      Glad to know that you got the solution. Can you please share the steps you took to overcome the issue so that other users can also get benefitted?
    • ankush.choudhary
      Hello Naresh Patre
      Off course I would love to share the steps:
      1. I deleted my temporary file from my cache memory.
      2. I restarted the application and run the simulation again and then I was able to extract the results.
Viewing 4 reply threads
