September 5, 2019 at 11:20 am
September 5, 2019 at 12:14 pm
September 5, 2019 at 12:38 pm
Ansys EmployeeHave a look in the DesignModeler documentation, 3D Modelling > Concept Menu > 3D Curve and compare what you've written with that. Also check for white space characters.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
