October 1, 2018 at 2:03 am
FlamingWizard
SubscriberWhenever I try to import Geometry from SpaceClaim or from .stl file generated through Catia V5-6R2017 in Design Modeller, I am facing following PlugIn Error
Design Modeller states that it is unable to import Geometry due to Plug-In error.
I tried reinstalling software, rechecked file, tried archiving and even changed save location but to no help.
October 1, 2018 at 4:39 am
Keyur Kanade
Ansys EmployeeHello,
Are you able to open SpaceClaim and Design Modeler?
Can you please create simple box geometry in SC or DM and then open Model?
Which version you are using? Can you please try R19.1?
If you have STL file, usually we import in SC. STL is faceted data. In SC we convert it to solid geometry as you can see at following link. Then we use this geometry further.
http://www.spaceclaim.com/en/Solutions/ReverseEngineering.aspx
Keyur
October 2, 2018 at 12:26 am
SubscriberDear Wizard,
Are you creating solid models in Catia? If you want to transfer solid geometry from Catia to ANSYS DesignModeler or SpaceClaim, you should not choose STL as the neutral file. Try exporting Parasolid or STEP neutral files from Catia to import into DM or open in SC.
October 3, 2018 at 2:18 am
FlamingWizard
SubscriberHello there,
Thanks for replying.
Yes I am able to open SpaceClaim and Design Modeller. The design is just a 2D profile of a rectangular plate of 1mX2m. The particular design is for Steady State Thermal Analysis. I followed all the instructions shown in videos.
I tried this on Version 19.0, 19.1 and 19.2
Geometry
Meshing
I am pursuing a course in EdX on Hands on Introduction to Engineering Simulations conducted by Cornell with Ansys.
October 3, 2018 at 2:36 am
FlamingWizard
SubscriberHi @peteroznewman thanks for replying
I tried exporting the geometry as STEP file. I am using Catia V5-R2017 student version and it is showing .stpZ as one of the options apart from IGES and STL.
The result is still the same. Still showing PlugIn error "Can't import geometry".
October 3, 2018 at 3:26 am
SubscriberHi Wiz,
The .stpZ file is a compressed STEP file that ANSYS doesn't know how to open.
You can install the free 7-zip archive manager that can uncompress the .stpZ file into a normal (uncompressed) .stp file.
Once you have the .stp file, SpaceClaim will be able to open it.
However, I agree with Keyur's comment below that you can draw that shape very quickly from scratch in SpaceClaim.
October 3, 2018 at 3:27 am
Keyur Kanade
Ansys EmployeeHi,
Can you please follow steps in tutorial first. Please create geometry in SpaceClaim and move to meshing. Let us know if this gives problem.
These are very simple steps in SpaceClaim. You may not require CATIA for the same.
Keyur
January 24, 2019 at 3:29 pm
January 25, 2019 at 2:08 pm
Ansys EmployeeI'm not sure which CAD readers come with Student: also dxf isn't a great format for transferring data. In the short term use STEP (no reader required and safer than IGES). What happens if you open DM? Can you see the CAD?
January 25, 2019 at 2:25 pm
sathya
SubscriberHi,
From my experience,I would suggest you to export using PARASOLID format because DesignModeler uses PARASOLID geometry modeling kernel ,while SpaceClaim uses the ACIS geometry modeling kernel.
Prefer PARASOLID to keep data loss minimal in DM.
April 26, 2019 at 8:59 pm
michaelemery14
SubscriberI'm struggling with a similar issue, I have a series of 2D aerofoils that I need to capture the Cl from and I have all of them in the SpaceClaim format, as soon as I try and import them using DesignModeler it doesn't work. I've tried changing them to STEP files, PARASOLID but nothing seems to be recognised by DM.
Any help would be greatly appreciated
Many thanks
Mike
April 26, 2019 at 9:20 pm
michaelemery14
SubscriberNot to worry, I've solved it. The aerofoils had to be a filled 2D surface to import them into DM, I hope I've helped other newbie's at this easy but frustrating problem!
July 12, 2019 at 9:55 am
Subscribervidhan, please start a New Discussion to post your question and delete the post above.
In the New Discussion, insert an image of your geometry and describe it in more detail.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
