August 23, 2023 at 12:09 pm
Aniket Parida
SubscriberIn Ansys Aqwa I'm facing these errors while meshing. I've tried reducing the element size and using sizing control, but nothing worked.
I have already done the hydrodynamic diffraction simulation for each element of my assembly and everything just worked fine.
Error 1 : "The meshing engine has failed to generate a mesh on all faces and surfaces. You may need to reduce the Element Size, or use Mesh Sizing to reduce the local element size on small faces."
Error 2 : " Some problems occurred during the meshing operation; Workbench has been unable to generate a mesh."
August 24, 2023 at 1:56 pm
Mike Pettit
Ansys EmployeeHello,
Are you able to share a screenshot of your geometry? Can you also try importing the mesh into Mechanical, to see if you can generate a mesh there?
Mike
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
7646
4468
2957
1427
1322
