March 9, 2023 at 7:22 am
March 9, 2023 at 7:55 am
SRP
SubscriberHi,
The .cdat file should be saved in the same folder as the case file which produced the data. Then when you read the .cdat file into ANSYS CFD-Post, the associated case file will also be read in automatically. If they are not saved in the same folder, ANSYS CFD-Post will prompt you to specify the appropriate case file.
Thank you.
March 9, 2023 at 8:49 am
FERO86
Subscriberyes both case and .cdat files are in the same folder.
March 9, 2023 at 3:45 pm
Ansys EmployeeCan you copy both files and rename to remove the brackets? Using any unusual/command characters in the CFD tools tends to cause problems as they were originally UNIX based.
3670
2550
1749
1226
582
