Ansys Free Student Software
Error while opening wbpz file
    • Raunak15
      This is the error message that I am getting while trying to open a .wbpz file.
      I am running Ansys Aim 19.0
      I will appreciate any help with this regard.
    • raul.raghav
      Could you share the workbench archive file here so we could take a quick look?
    • Raunak15
      I have attached the workbench archive file.
      Thank You 1
    • peteroznewman
      I recognized the file name and used ANSYS 18.2 to open that archive, which is from the CornellX course on edX.org. They recommend you install ANSYS Student 18.2 for that course.
      I suggest you uninstall ANSYS AIM 19.0 and then install ANSYS Student 18.2, which can be found under Prior Release link.
      If installing AIM 19.0 was intentional and not a mistake, then reply to confirm that and we can talk about how to build that model in AIM.
    • Raunak15
      It works fine on 18.2 but I was wondering if there is a workaround other than building the model from scratch.
    • peteroznewman
      I don't know about moving from Workbench to AIM, but you can export the geometry out of the Geometry editor and save that to a file, then in AIM, you can import that geometry from that file.
    • Raunak15
      Yes that works!
      Thanks for the tip.
Viewing 6 reply threads
