September 4, 2019 at 7:55 pm
September 4, 2019 at 8:21 pm
September 14, 2019 at 7:07 pm
Ghost3507
SubscriberThank you for your help. I updated the model and this is the new error that I am facing:
DP 1) The Model component in Static Structural for Design Point 1 requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic.
September 14, 2019 at 11:44 pm
SubscriberDo you have geometry parameters in SpaceClaim or DesignModeler?
If you are not careful, you can set a value on a geometry parameter that eliminates a face that a Load or BC was assigned to, then the Model will need to be repaired.
Study what happened to this model.
2138
1355
1136
462
