Error while solving .
    • sujeth
    • sujeth
      I done the drawing in catia and uploaded the .stp file. Here I meshed the model using linear mesh order and generated the mesh. But while solving I get these errors which I uploaded in above post.
      The model consists of helical and circular ribs and the outer skin which obtained using pad. Do I need to do something like joining the ribs and the top & base surface properly? How to do it?
      I'll also upload the file if required and I request you to share with me which format to upload.
      Thank you.
    • dinhan0394
      Your model have 3 bodies but I don't see any connection between them.
      Try to fix it by:
      Create Contact in Connection branch.
      Import the geometry to SpaceClaim or DesignModeler and active Share Topology
    • sujeth
      Thank you
Viewing 3 reply threads
