Error while solving the project
    • Md Ahad
      i was facing the problem while solving the project . An error message was sent when i tried to solve. An snapshot and the file is attached below
    • Sandeep Medikonda
      Hi Ahad,
        Some possible reasons are:
      • You may be running out of disk space during the Mechanical solution due to the writing of large solution files. Verify that there is sufficient free disk space on the drive where the solver directory exists.
      • You do not have write permissions to the solution directory.
      • Files from a previous Workbench session might already reside in the solution directory.
      Also, in the structure tree, Go to solution information under the Solution folder. The error should be written there.
      So check for these.
      Sandeep
    • Md Ahad
      Thank you very much
