January 24, 2021 at 10:03 am
nariox
SubscriberHi guys,
Do You have idea why this happens? i guess the problem is in the whitespaces characters.
The scirpt want to execture D:Nowy_folderAnsys and take the path D:Nowy_folderAnsys Inc not into cosideration.
Do You have any ideas how to solve this? or how to rename ANSYS INC into ANSYS_INC and check if it works?
simply renaming causes error while trying to open launcher.
BR,Marcin
January 25, 2021 at 2:37 pmANSYS_MMadore
Ansys EmployeeArrayWhat are you using for your settings under the File Management tab and Customization/Preferences tabs? Can you open a Windows command prompt and enter the command set without quotes and send the full output?nFebruary 16, 2021 at 7:08 amDera16
SubscriberDear respected friends and professionals of ANSYS,nfirst of all i would like transfer my warm greeting to all of you,ndo you know why this kind of problem happened when i make/do run ls-dyna solver?i tried many times ,but the problem is repeatedly happened,so please help me .thank you for your kindness support.nn
February 26, 2021 at 6:11 pmANSYS_MMadore
Ansys EmployeeArrayCan you please share full details of the screens you are accessing and the entries you are using in any of the fields or submission settings? Please also open a Windows command prompt and enter the command set without quotes and send the full output.nViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5290
3299
2469
