Discovery Import
Discovery Import
Error while updating physics
    • starrynightwalker
      When I attempt to update the physics,I meet the problems as blew.Do you have any suggestion?Thanks in advance!
       *** ERROR ***                           CP =       0.250   TIME= 18:11:05
       The license is currently in use by another application in this
       Workbench session such as Mechanical or another Mechanical APDL
       application.  You must wait until the other application has finished
       its task (for example meshing) or manually PAUSE the other Mechanical
       APDL application.
    • richard.clegg
      Starrynightwalker Your subscription license only allows you to solve one AIM simulation at any one time. This message indicates you already have an AIM simulation running. If you save and close the other AIM session you should find the simulation here will solve.
