Ansys Products
Ansys Products
Error with Aqwa GS- PAG: files are not created
    • danielbar
      recently I couldn't create wave/pressure contours or generate plots via the Aqwa GS due to the fact that .PAG files are not created. I checked it also on files that it used to work for in the past. Does anyone know what the problem could be?
      Thanks.
    • Yu Bi
      Hi, this problem is due to a 'Y2K' bug in Aqwa which affects all released Aqwa versions since 1stJanuary 2022.This bug will be fixed in the 2022R1 service pack in mid-February. The workaround to generate *.PAG file is to manually add SEAG data record (Aqwa Reference Manual Section 6.13) in the *.DAT file before running Aqwa. However, for the pressure contour, it can only be plotted in the Aqwa Workbench editor, i.e. AqwaGS cannot plot the pressure contours currently.
    • danielbar
      Thank you for your detailed answer! I appreciate it!
