Ansys Free Student Software
Error with CFX Solver
    • Adrián Delgado
      Good morning, during the simulation with Ansys Workbench, I have a problem when using the Solver, I get an error saying that the folder or file does not exist, I do not know if it is a problem that it is going to look for it a directory that is not, or which could be.
      Vista previa de imagen
    • Nikhil Narale
      Did you share 2 screenshots? I can see only 1, and the error on that looks different from what you mentioned in the description.
      If so, can you post the screenshots again? Thanks
    • rfblumen
      Without seeing the first screenshot, one thing that might cause this error (file or folder does not exist) if there are non-standard characters (i.e. "<","(", and so on) in the file path.  I would try to only have letters, numbers and underscores in the file path to avoid issues.
