Ansys Products
Ansys Products
Error with mesh workbench fluent
    • zouaoui
      I couldn't open mesh in workbench fluent and the error is error waiting for meshing initialization to complete. object reference not set to an instance of an object
      So how can I do to fix this problem
    • Matt Madore
      Can you please search for other posts referencing the text: Unable to start the Meshing editor or Object reference not set to an instance of an object. Please refer to suggestions from other similar posts.
      Just a couple of threads:
      https://forum.ansys.com/discussion/comment/89104#Comment_89104
      https://forum.ansys.com/discussion/comment/80722#Comment_80722
    • zouaoui
      I did all what you they said in the comments but i didn't get any result it's the same error
    • zouaoui
      I didn't solve my problem yet
      The error is with meshing and it's the same error always so what can I do
      Please someone help me.
      Thanks.
    • Matt Madore
      Please open a Windows command prompt and send the full output of the command "set" without quotes.
      Please also run the command "dxdiag" and send screenshots of each tab of the Dxdiag utility that launches.
    • zouaoui
      Thank you so much for replying
      So this is all what I had from the commands
      This from the command set
    • Matt Madore
      Please share the actual text output and paste screenshots into your response. We cannot download attachments.
    • zouaoui
      This is for the command set
    • zouaoui
      and this for the command dxdiag
    • Matt Madore
      It appears you do not have a Workstation graphics device and only the Intel graphics. You can try updating your Intel graphics driver, but this may require you use a machine with a better graphics device from Nvidia or AMD.
    • zouaoui
      Okay, thank you so much for the help
Viewing 10 reply threads
