August 23, 2023 at 7:11 am
Julio Mariano Geronimo
SubscriberBelow is the circuitry that I have built:
I have selected Linear Network Analysis option and I have analyze my circuitry.
This error pop up:
I understand that my error is regarding the transistors, but I dont know what should I edit.
Could it be due to the MOD row not being filled up:
If yes, what should I insert into the MOD row?
August 24, 2023 at 2:47 pm
dedgar
Ansys EmployeeHI Julio, The NMOS device requires a suitable model definition (card) to supply the required parameters etc. Model cards are available in the component libraries for different transistor types. If you have a look at the examples for the DIfferentialAmplfier, you can see the setup (bjt in this case)
Mosfet model cards are found here:
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7780
4508
2973
1449
1322
