LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Error with Steinberg-Guinan Strength model and other models
    • Alex Horwege
      I have been using Johnson Cook models in my impact analyses, and I wanted to try some other constitutive models. I am running into an error where the material models are not recognized, including the models that come built-in with ANSYS Workbench (STEEL V250 for example, with Steinberg-Guinan strength model and Mie-Gruneisen EOS).
      How can I implement these models in LS-DYNA for ANSYS Workbench? Here is the error code from the Solver output below. It looks like it simply is not detecting the material model at all. I am currently using it with an SPH mesh, but I get the same error with other mesh methods too.
      Beginning of keyword reader                                   11/17/23 17:55:35
       *** Error 10157 (KEY+157)
           MAT 2 is not found
       *** Error 10304 (KEY+304)
           CHECKING MATERIAL INPUT Part ID= 2
           PART ID 2 with
           SECTION ID 2 and
           MATERIAL ID 2 does not exist.
           This is PART 2 in the order of input.
       *** Error 10133 (KEY+133)
           input data failed with: 4 errors
       E r r o r   t e r m i n a t i o n                             11/17/23 17:55:36
    • Ram Gopisetti
      The closest match for such material in LS-Dyna is MAT_011,
      You may want to check that material definition first, then use Command snippets under the scoped body.
      Native implementation is not made yet.
      Cheers, Ram
