August 1, 2018 at 4:19 am
MoedaVerde
SubscriberI tried to install the ANSYS Student package 19.1 and this SceneGraphChart problem pops up. I saw the post that a guy wrote here in the forum asking for help for the same problem, but the solution given to it did not work for me at all.
An unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit. --- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit. --- System.Exception: SceneGraph.Engine - failed to boot up. at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler) at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context) at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin) at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
I have Windows 10 Pro x64;
I changed my username to one without accent and space;
I tried install both on Cand D
(Both physical local driver);
I always open with administrator privileges;
I tried everything that tsiriaks say on this post:
https://forum.ansys.com/forums/topic/ans-scenegraphchart-scenegraphaddin/
But nothing changes. Please, anyone can help me?
Thanks in advance and please ignore some misspelling in my text.
August 1, 2018 at 12:24 pm
JakeC
Ansys EmployeeThis could also be graphics card related.
Please update your graphics drivers to the latest version, and verify that the "good" card is enabled as the primary card.
For instance if you are using a laptop with an intel card and an nvidia card in it, open the nvidia control panel and 3d settings, and verify that "High Performance Graphics Processor" is selected as the primary card and not "auto detect"
Which graphics card are you running?
Thank you,
Jake
August 2, 2018 at 3:02 am
MoedaVerde
SubscriberMy video card is a GEFORCE GTX 1060 updated. I wonder, is this problem because the Ryzen 7 processor has no GPU?
August 2, 2018 at 4:34 pm
tsiriaks
Ansys EmployeeHi MoedaVerde,
Could you provide screenshots of 'dxdiag' just like user SK_Runek provided in
Also, have you tried Jake's suggestions for Lindsay (from the same post above)
Can you try closing all open ansys applications and rename the following directory:
%APPDATA%Ansys
to
%APPDATA%Ansys_old
Then try launching workbench from the shortcut again.
You may also want to try running ProductConfig:
Start -> All Programs -> Ansys -> Utilities -> Right Click on Product and Cad Configuration -> Run As administrator
Then click on Configure Products and Cads and follow the prompts.
Thank you,
Win
August 16, 2018 at 1:08 pm
CelioGP
I have the same problem. I have a Nvidia GeForce GTX 745 video card
August 16, 2018 at 1:18 pm
JakeC
Ansys EmployeeHi CelioGP,
Which suggestions from this thread have you tried thus far?
Additionally, please try the suggestions in this thread:
Thank you,
Jake -
August 16, 2018 at 9:48 pm
CelioGP
SubscriberHy JCallery
I renamed the% appdata% / ansys directory to ansys_old I have already done this: Start -> All Programs -> Ansys -> Utilities -> Right Click on Product and Cad Configuration -> Run As administrator I already updated the driver of my video card. Follow the error and dxdiag photos
https://drive.google.com/file/d/1iwG-SmdBVltZDXJqv4YR5Eq4uTgArH8H/view?usp=sharing
https://drive.google.com/file/d/1dV1HsWROVubmdEPmOl6WUp6_CmUfmMio/view?usp=sharing
August 17, 2018 at 5:04 pm
JakeC
Thank you.
Could you please try changing your language and locale to English and en-us?
Thank you,
Jake-
November 2, 2023 at 1:51 pm
Tong Li
SubscriberHi Jake
I think u r right I fixed it by changing my language need to be uniformed and not use beta version
thx for saving me fr having to reinstall
August 22, 2018 at 1:56 am
CelioGP
SubscriberJcallery,
how do I do that?
August 22, 2018 at 12:25 pm
JakeC
Ansys EmployeeDepending on your version of windows, please try something like the following:
https://www.wikihow.com/Change-the-Language-in-Windows-7
Thank you,
Jake -
August 27, 2018 at 6:25 pm
aliberati
SubscriberHi all,
As a follow-up of these questions, I was having the same issue on my computer with the Ansys Student Pacakge under Windows 10.
I tried most of the advice you offered :
- updating my graphics cards drivers - I have a Intel(R) HD Graphics 530 and a NVIDIA GeForce GTX 960M
- running my Nvidia control panel and setting the "high performance processor" instead of "auto-select"
- renaming the %appdata%Ansys to %appdata%Ansys_old
- running ProductConfig which seemingly had nothing to change
- installing on both my C: (SSD harddrive) then my(HDD harddrive)
- running an existing project to at least open something of the program
- restarting my computer after each process
None of these worked.
The last step I tried was changing my username on Windows. I wanted to change my user folder name that contained accents, but failed to do so - instead I changed the session username to a name without accents (I accessed the Advanced User Accounts panel by looking for "netplwiz" (Windows application), by clicking on my user name, then Properties, then by changing the name, applying the settings and rebooting the computer) : surprisingly enough, this worked actually.
After rebooting, I could open the Workbench and launch the different processes.
Now I am having other issues though as Fluent won't launch with another list of error codes - but I guess it wouldn't be relevant here. At least I have the Workbench now.
Best of luck to the other reading this who may have issues.
(EDIT : Issues with Fluent may still be related to the "accent situation" as it searching for files from C:UsersD?d?... whereas files are in C:UsersDédé...)
MAJOR EDIT : Apparently, "just changing" the User folder name is impossible and requires creating a new account or reinstalling Windows (https://answers.microsoft.com/en-us/insider/forum/insider_wintp-insider_security-insiderplat_pc/rename-user-account-folder-in-windows-10-preview/88033eca-6b32-47c5-90ac-a5e7af17d094). So I created a new User account (took 5min), made sure I had no accents in the name (called it Ansys) and now it's working like a charm. Hopefully this can solve your issues future readers ! -
August 27, 2018 at 8:48 pm
tsiriaks
Ansys EmployeeHi aliberati,
Thank you for sharing your resolution. This would definitely be helpful to others.
Thank you,
Win
November 3, 2018 at 11:24 pm
frank2243
SubscriberDid anyone have ever found a solution for this problem?
I have Windows 10 installed on an iMac 5K with the latest AMD drivers.
November 5, 2018 at 6:44 pm
tsiriaks
Ansys EmployeeHi frank2243,
See the discussion here
https://forum.ansys.com/forums/topic/installation-problem-in-workbench-19-2/
If this doesn't help, please create a new thread.
Thanks,
Win
May 20, 2019 at 3:59 am
ra9841lu
SubscriberYes, that's the solution, I have (or had a minutes ago) the same problem, with that message I tought it was my GPU (GTX 1070 laptop) or the fact that I use a laptop so I need to change from the intel gpu from nvidia one for ANSYS, but no. The problem was that my windows is in Spanish and my user name have spaces and an accent (Raúl...), so I just create a new user account in english and just named Ansys, and worked! thanks, mention that I tried all the other solutions but not worked. I really wonder if you can on the next uptade fix this error please.
May 20, 2019 at 4:41 pm
tsiriaks
Ansys EmployeeHi ra9841lu,
That's great. Thanks for letting us know.
We've submitted this enhancement request to our development team. Hopefully, this is improved in the near future release.
Thanks,
Win
September 11, 2019 at 6:55 am
pallavinataraj
SubscriberHi,
Ansys electronics desktop is giving error message when i try to open 3d component as" this 3d component is created in future version of this product and cant be open in this" My ansys electromagnetic suite is 19.2 version..kindly help to fix this error
September 11, 2019 at 9:00 am
Forum ModeratorIt means that the model you're trying to open was created in a newer (probably 2019Rx) version of the code. You need to update to the later version to open the model.
December 14, 2019 at 5:14 pm
cafcafliayakkabi
Subscriberhello guys, i had the same problem for about 10 days.now, I got over with these problems.
I would like to say how to I got over this issue "unexpected error the following required addins could not be loaded...etc"
First of all , this problem arise from using a letter which does not belong in English language.For ex,, ? i ç ,ü,?...etc
So, first thing that you have to do , press Windows +R buttons and write "netplwiz" afterthat you will see your account(s). then add new account name with english letters.(You dont need to create with microsoft e-mail and just click local account.)And give it administrations.Before next step ,you had better backup your files because you will delete it,your current account.But it is not big deal to get back your files because you have already downloaded your files. just you might spend your time to find where the files in.It worked on me. now i can use these ansys apps. I hope it will work on you.Good Luck!
Emre
December 19, 2019 at 6:23 pm
tsiriaks
Ansys EmployeeThank you for sharing your resolution Emre
Win
February 6, 2020 at 10:48 am
April 11, 2020 at 9:57 pm
hidalgoatomas
SubscriberHi, I created a new account on my computer but i dont understand what is the next step. I'm trying to install 2019 R2 version.
Thanks! -
April 15, 2020 at 10:35 pm
tsiriaks
Ansys EmployeeIf you have not already done so, please create a new thread and describe the issue with screenshot of error (if exist)
Thanks,
Win
November 15, 2020 at 5:34 pm
puzite
SubscriberAfter I updated windows this error started to appear when I tried to open workbench 2020 r2 and no solution posted here has worked for me. I have tried to reinstall ansys multiple times on older windows versions and also on other users. Only solution I haven't tried is to reset my PC but I really want to avoid that. nIs there any other solution?n
November 23, 2020 at 10:27 am
puzite
SubscriberNvm I just fixed itn -
December 9, 2020 at 1:01 pm
Francis
SubscriberHi, I’m having the exact same problem as you presently. I’ve tried all of the above solutions. How did you manage to fix it? thanks! francis -
December 9, 2020 at 1:05 pm
September 24, 2022 at 4:25 am
Dohyun Kim
SubscriberI met this error changing my windows utf-8 preferences, so you may try:
- Open the Windows Control Panel
2. Select [Clock and Region]-[Region]
3. Open the [Administration] Tab
4. """UnCheck""" "Beta: Use Unicode UTF-8 in worldwide languages" from "Change system locale".
5. Restart Windows.
In my case, I solved this error after restarting window.-
August 7, 2023 at 2:55 pm
Joao Miranda
SubscriberI tried to use this method, but solidworks stopped working, is there a way to make solidworks work with this method?
February 20, 2023 at 5:51 pm
Abhinav kumar singh
Subscriberthe same problem but not solved after many attempts. please help me.
March 10, 2023 at 2:41 am
Zexin Shan
SubscriberIt is 2023 now. The same problem still exists. I've tried everything posted here but none of them works. Just decided to give up using ANSYS.
March 22, 2023 at 12:22 pm
TJ
SubscriberEin unerwarteter Fehler ist aufgetreten: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
--- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.--- System.DllNotFoundException: Die DLL "SceneGraphChart.Components.dll": Die angegebene Prozedur wurde nicht gefunden. (Ausnahme von HRESULT: 0x8007007F) kann nicht geladen werden.
bei Ans.SceneGraphChart.Engine.Ans_SceneGraph_Bootup(Object p_iConfiguration, Object p_iErrorHandler)
bei Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
bei Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)
bei Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
bei Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)Same here.
What is the solution?
June 20, 2023 at 8:10 pm
Benjamín Cruz Cuba Guzmán
SubscriberHello i would like to know how to solve this problem, im trying to use Ansys Student 2023 R1, when i lunch Workbench this happens:
--- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.--- System.Exception: SceneGraph.Engine - failed to boot up.
at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)I don't know what to do, but i need to find a solution early, because i have to make a proyect for my class
June 21, 2023 at 6:45 am
Remi Roux
SubscriberHi everyone,
The same issue happened to me, and I find something additional in the “changing your username” solution.
My username initially had an accent so I changed it. However, nothing changed because the Users folder containing the data of the account still has an accent. This is because the Users folder takes the current account’s name at its creation. Hence, changing your account name would not change the folder’s name. And then, when Ansys wants to access personal data, etc, it goes through this folder with an accent, and that is the problem.
I do not know how to change the name of this folder but I think that is one of the cause.
I forgot to mention: The desktop I am using has different profiles and different accounts. So for me, there are no issues with graphic cards,... I am the only one with this issue and the only one with an accent. Since ANSYS is an American software and they do not use accents, I would not be surprised if it is only that. For example, if you try creating an account for an American software with an accent, they often mark an error that the name is not valid.
October 10, 2023 at 2:25 pm
Hridoy Saha
SubscriberI also faced this problem,after that I just changed my username properly without any space and special chararcters.So you guys can follow this video to change your username and fix the problem.For Check your user name go to my pc>user Here's the video link .......
- License Error
- how to open DesignModeler
- FlexNet Licensing – Not running
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
- Numerical Problem Size limits with a model that should run
8808
4658
3151
1680
1470
