August 10, 2021 at 4:25 pm
Abubakar
SubscriberHi Sir,
I performed the Sod shock tube simulation and the simulation worked successfully, but by checking the contour it comes empty as illustrated below:
August 12, 2021 at 3:30 pmRK
Ansys EmployeeHello,
Can you please check in the WB folder to see if Fluent is writing out the necessary files and let us know? Thanks.
August 12, 2021 at 3:51 pmAugust 12, 2021 at 5:52 pmKarthik R
AdministratorHello It also looks like your simulation diverged. Please double-check your model set-up.
Karthik
August 13, 2021 at 5:16 amAbubakar
SubscriberI did not modify the setup I directly ran the setup (final_case_setup) provided in the Ansys innovation course.
Thank you Abubakar khan
August 13, 2021 at 1:32 pmRK
Ansys EmployeeHi Abubakar,
Can you please try running this in Fluent standalone and let us know if the run is successful?
August 13, 2021 at 2:05 pmAbubakar
Subscribersure will do that.
August 17, 2021 at 12:54 amKarthik R
AdministratorHello Start from the initial case & data file and try running the simulation. This is a transient simulation and it would only have the data from that time-step. Please re-run the simulation from t = 0.
Hope that helps.
Karthik
Viewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- How can i get stress-strain data points for defining Multilinear isotropic hardening in Ansys
- Reynolds Number in Fully Developed Turbulent Flow
- Opening course files using ANSYS 19.1
- Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Error Object: #f
- Formula SAE Composite Monocoque Chassis Analysis – Geometry File
- Mesh fail
- Coriolis Flowmeter 2 way FSI workshop files
- Turbulent flow
- Ansys innvoation course files
- How to get the Ansys Course Completion: Intro to Python Badge
2656
2120
1345
1118
461
