January 10, 2020 at 8:48 am
rg
SubscriberHi
Several customers have automatically updated windows including myself.
Now when trying to open a scdoc file it no longer opens (as in the video)
How do I solve this problem?
Best Regards
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
January 10, 2020 at 10:19 am
Naresh Patre
Ansys EmployeeHello Robert
Please check out below article:
FAQ: Configuring Recognition of External CAD Formats in Windows
January 10, 2020 at 12:00 pm
rg
SubscriberNaresh Patre I tried but it still doesn't work
January 10, 2020 at 11:31 am
rg
SubscriberNaresh Patre Hi Naresh
is not an external file, no longer opens scdoc files (spaceclaim native files)
How do I solve?
Best Regards
January 10, 2020 at 11:38 am
Naresh Patre
Though the title of the article mentions about external files, the same solution is applicable for the double click issue associated with scdoc files.
January 10, 2020 at 11:40 am
rg
Hello
So the windows update has probably changed the registry keys?
Thanks then I will follow your instructionsBest Regards
January 13, 2020 at 6:29 am
Naresh Patre
Can you try below approach and see if it helps:
Right-click on any scdoc file and select "Open With" -> "Choose another app". Refer below image.
Next, select the required version (for example SpaceClaim 2020R1), then enable "Always use this app to open .scdoc files" option located at the bottom and then click "Ok". Refer below image.
January 13, 2020 at 7:31 am
rg
Hi Naresh
thank you, these are the first tests that I always run.
I solved it by changing a different registry keyBest Regards
3694
2564
1765
1234
590
