Installation and Licensing
Errors while running the HFSS 2023 on linux server
    • hedayat99
      I have an HFSS 2022 installed on the Linux (Redhat) server, and it's working. Recently, I also installed the HFSS2023, but it is not opening. I re-install it, but I am still getting the same error message. It gives me the following errors. I would appreciate it if someone could help me figure out this issue.
      • > Running first-time configuration for [username here]...
          - *** Dependency verification test disabled by default ***
            [ Use 'export ANS_DEPCHECK=1 ; ./ConfigureSoftware.bash --fullconfig' ]
          - Retrieving user settings... Done
          - Applying user settings... Done
      • The following additional errors were detected:
          /home/tools/HFSS/v231/Linux64/helic/share/python/lib/python3.9/site-packages/h5py/h5g.cpython-39-x86_64-linux-gnu.so (ldd error): /home/tools/HFSS/v231/Linux64/helic/share/python/lib/python3.9/site-packages/h5py/h5g.cpython-39-x86_64-linux-gnu.so: error while loading shared libraries: libhdf5_hl-84bfe2a0.so.200.0.1: ELF load command address/offset not properly aligned
    • JINBO Mi
      hallo, maybe there are some problems while loading the needed lib and software.
      1.do you have give the access right for the software to install with the folder
      2.if there is a config file have not be writed, for the common sense, to start a installaition on the linux and unix, it is needed to change the config file
      3.if you have removed all the files of the old edition of the software
