November 17, 2022 at 3:55 pm
Alimkhan Zhanturlin
SubscriberHello, I faced errors with opening my 2d mesh file in Ansys Fluent. It says "
Error: File "C:\Users\alimk\OneDrive\??????? ????\NU\capstone\aa_files\dp0\FFF\MECH\FFF.msh" not found!
However the file exists.
November 17, 2022 at 3:57 pm
Alimkhan Zhanturlin
Subscriberalso in WorkBench it says"
Ansys.Fluent.Cortex.CortexCommandFailedException: An error occured in FLUENT while applying case and settings informatins.
at Ansys.Fluent.Cortex.CortexCommunicator.SendMessage(String msg, String msgKey, String errorMessage, Boolean waitForReply)
at Ansys.Fluent.FluentCommunicator.UpdateSetupInfo(Dictionary`2 info)
at Ansys.Fluent.Data.SetupData.ReadCaseModelInfo(IFullContext context)"
November 17, 2022 at 4:17 pm
Forum ModeratorAssuming the ?????? section is just to hide a path name and there aren't any odd characters can you check Fluent in standalone mode, you'll need to copy the mesh file out of the folder.
November 17, 2022 at 4:35 pm
November 17, 2022 at 4:55 pm
Forum ModeratorCan you move the mesh to C:/users/alimk and try? If those ??? are real it'll cause a problem.
- License Error
- how to open DesignModeler
- FlexNet Licensing – Not running
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
- Numerical Problem Size limits with a model that should run
8762
4658
3151
1678
1456
