October 29, 2023 at 4:08 pm
October 30, 2023 at 10:59 am
Rajeshwari Jadhav
Ansys EmployeeHi Yusuf,
Go to C:\Program Files\ANSYS Inc\Shared Files\Licensing directory, copy the ansyslmd.ini file to the desktop location.
Open the ansyslmd.ini file using Notepad and add the following lines –
ANSYSLI_FNP_IP_ENV=1
ANSYSLI_TIMEOUT_FLEXLM=20
ANSYSLI_FLEXLM_TIMEOUT_ENV=20000000
ANSYSCL_TIMEOUT_CONNECT=60
ANSYSCL_TIMEOUT_RESPONSE=300
Once you add the lines, click Save As > ensure that the save as file type is ‘all files’.
Once the file is saved, please replace the old ansyslmd.ini file using the newly created one.
Also set the following Environment Variable –
Go to START > ‘Edit the System Environment Variables’ > click Environment Variables.
Under the System Variables, please click NEW and create a new variable.
Variable Name – FLEXLM_TIMEOUT
Variable Value – 50000000
Save it.
- Config File Reset -
Now open a file explorer and type %appdata% in the address bar.
Locate the Ansys folder and rename it to Ansys.old.
Now try launching Workbench application to see if it loads without any issue.
- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
- Fluent Meshing Error (Scope To: edges/faces and edges)
8808
4658
3153
1680
1474
