January 18, 2023 at 8:02 am
Diogo Martinho
SubscriberHi all,
Probably not a good question but I understand the eulerian model solves a set of equations for each phase. However, when I start my simulation and check the equations I only have a continuity equation and then a vf-gas equation. Is this vf-gas the continuity equation for the secondary phase? -
January 18, 2023 at 9:13 am
DrAmine
Ansys EmployeeBy default only the secondary phase volume fraction transport equation will be solved. With the compatbility condition the volume fraction of the primary phase is calculated.
A bulk pressure continuity equation is always solved.
January 18, 2023 at 9:20 am
Diogo Martinho
SubscriberHi, thanks for your quick answer.
Can you detail a bit your answer?
So, the continuity equation there (black line) is the primary phase continuity equation. And then I am solving a transport equation for the volume fraction and because of the constraint that the sum of alpha might be equal to one, I have the volume fraction of the liquid phase? -
January 18, 2023 at 10:13 am
DrAmine
Ansys EmployeeI think I was clear as I wrote we are solving a pressure continuity equation for the bulk and not for the primary phase. The primary phase volume fraction is calculated from the 1-sum_over_all_secondary_phases(volume fraction).
January 18, 2023 at 10:28 am
Diogo Martinho
SubscriberOk, thanks.
So, let's say we are simulation water-oil-hydrogen, and they are defined as three phases where, water will be the primary phase and the remaining secondary phases. Will I have a continuity equation for the oil, another for the hydrogen, a continuity equation for the pressure (I am not entirely sure if I understood this equation though) and finally, the water will be 1-sumover_all_secondary_phases(volume fraction)? -
January 18, 2023 at 10:33 am
DrAmine
Ansys EmployeeYes. (Pressure Based Continuity Euqation: Check Solver Theory and you will perhaps understand what I am talking about).
2610
2088
1321
1108
459
