May 23, 2023 at 5:10 pm
Patrick Kirby
SubscriberHello All,
I've made several post prior as I've been working on my model and I think to push my project further I'm going to make use of the aforementioned methods. Relating to this, I have a few questions.
1) The diameter output for the respective phase is the average or the Sauter Mean Diameter? I use the Sauter Mean diameter to define my moments (using QMOM for population balance, I solve multiphase single diameter first and then solve for QM and VF of gas phase) but I recall reading that the diameter output is the average diameter.
2) Why are some of my simulations/models unstable? I have both aeration and agitation (an air inlet and an impeler). For greater fluid velocities (greater inflow and agitation) I tend to run into solution issues (they could be computer issues, but its always hard to tell). If I make use of the mixture as opposed to the inhomgenous model I have a bit more success, but also some failure. I've looked to use the adaptive time-stepping to make my model a bit more robust, but even that runs into issues.
Thanks and have a good day
Pat
5180
3275
2453
