Eulerian multiphase model
    • soloviev
      I have a previous post about using the Eulerian model for a model of the air-sea interface. I am looking further into the Eulerian model and it seems that the secondary phase has to be particles (i.e. bubbles or droplets). I also see when setting the second phase that it requires a diameter size. I was trying to add my second phase (water) as half of the domain while the other half was moist air. When trying to do this I kept encountering initialization errors. Is this because the model does not work with large amounts of the second phase?
      Thanks,
      Alex
    • DrAmine
      The model does work with large amount of secondary phase. You can understand the diameter for a secondary phase which is morphologically continuous as sort of interfacial length scale which might affect drag and interfacial area.
      If you true separated phases I will activate MultiFluid VOF and use at first symmetric drag model. Please keep phase diameter to default and use interfacial area as gradient based
    • soloviev
      Thank you, I will try this.
      Alex
