Discovery Import
Discovery Import
Evaluation of differences between two location in Discovery Live
    • viochnova
      Hello, I have been trying new options in Discovery Live R3 and I have a problem with evaluation of differences between two location. In calculator there is possibility to choose Difference location Type, but when I use it and try to pick the faces of interest, I can not confirm my selections and so I can not evaluate the difference. I tried it for internal flow of simple pipe, I tried to pick inlet and outlet (face type in calculator), general faces in domain (planar surface choise in calcultor), planes (plane choise in calcultor), but the result was always the same. So how should I use it? What am I doing wrong? Thanks for help in advance. Natalie
    • Brian Bueno
      Natalie This was not immediately clear to me, but you have to manually click the Arrow icon when defining the calculator.  One selected face will be blue, and the 2nd will be orange.  At that point the Check mark will be active and you will be able to complete the selection.
    • viochnova
      Thanks for your help Brian! :-)
      For the next release, it would be helpful if these small changes in the procedure were mentioned in the description above, as it works as a guide, if I understand it well.
