Evaporation Below the Saturation Temperature
    • randojr
      I'm trying to model the evaporation of water droplets in a pipe. I saw that the evaporation-condensation model only works if the temperature of the droplet is above the saturation temperature. Is there some way to model evaporation below the saturation temperature? Would the only solution be to create a UDF?
      Thanks in advance
    • DrAmine
      Pure fluids will undergo phase change at saturation temperature assuming nuclei are there.
      What do you want to do?
    • randojr
      Hi Amine,
      Thanks, for the reply. I would like to model how water evaporates in air at temperatures below 100ºC. At the moment I can only get water to evaporate using the evaporation-condensation model at temperatures above this. Is there some way to easily model this?
      Thanks
    • DrAmine
      You need to write a small UDF for that. You need to use the Hertz Knudsen / Scharge formulation. The mass transfer is driven by pressure differences: partial pressure of water vapor in air to its saturation pressure.
    • randojr
      I'l try that, thanks!
    • DrAmine
      Welcome
Viewing 5 reply threads
