November 7, 2020 at 1:31 pm
CongestedHangman
Subscriberwhen i create a beam (say I-beam) in SpaceClaim using the beam profile in prepare tab, the beam remains transparent. without manually drawing, can i turn it to a solid shape if i use the beam profile? if i export the beam in other format (.obj) it's literally empty. [pic 1]nn -
November 7, 2020 at 1:54 pm
- The topic ‘Everything about Beam’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
