Exceeding an internal amplitude limit in the solver.
    • oumaimalahmar.ol
      hi peteroznewman
      First of all I simplified my geometry on spaceclaim and created the contact between each shell of the tank and then I applied my loads normally I have a weight force that is applied on the bottom of the tank as well as recesses.
      but the calculation doesn't work, I looked at the contact and it is well defined, I don't know what my problem is.
      thank you
    • Gary Stofan
      The message generally means that the model is not constrained. nTry a simple analysis with fixed supports(s) and gravity to make sure all contacts are working as expected. n
