3D Design
3D Design
Exceeding Geometry Limits in Ansys Academic Design Modeler
    • adam123newton
      I have been looking for the geometry limits for Ansys Academic and found various discussions threads stating that there is a body limit of 50 and a face limit of 300 (I have 200 faces) which I am below yet I still can't save my work due to geometry limits. Any help with my problem would be greatly appreciated.
      Thanks
      Adam
    • peteroznewman
      Hey Adam,
      You have found the correct limits.
      Maybe the limits are exceeded during the build of the geometry, even if the final shape is below the limit.
      Use another CAD system where you can create this shape, export a Parasolid from the CAD and import the Parasolid into DesignModeler. That would work.
      What if you create a surface from sketch instead of a solid, then there would be only one face. In Mechanical you can assign the thickness to that face and mesh with shell elements. Is that an option?
      Can you suppress the extrude features, then save the model with no solid body? If so, you can archive the project and attach the .wbpz file to your reply.
    • adam123newton
      Thanks for the quick response Peter,
      I think I did exceed the limits during that build, I think I can work around that if remake the geometry more efficiently.  If not I will do as you've suggested.
      Thanks Again
      Adam
