October 19, 2018 at 11:24 pm
saznavi
SubscriberHello,
I am modelling a coil in ANSYS Maxwell. I am using maxwell 3D and the simulation mode is magnetostatic. I there any way that I can change the excitation current phase angle?
Thanks
October 22, 2018 at 7:10 am
Keyur Kanade
Ansys EmployeeMoving this to Electomagnetic category for better response.
Keyur
October 24, 2018 at 8:30 am
ilies_alin
SubscriberI think magnetostatic is for magnetic DC simulation.
If you want a magnetic simulation and to use AC, change to eddy current.
There you could change the phase.
- Maxwell, HFSS or Q3D?
- Error
2564
2068
1289
1106
459
