November 13, 2018 at 8:43 am
Max4
Subscriber -
November 13, 2018 at 10:29 am
seeta gunti
Ansys EmployeeYou are displaying the velocity in the range b/n 0 - 30. Give the range b/n 0-3.
/dis con vel 0 3
Add the auto range by using /display set con auto-range yes
Seeta
November 13, 2018 at 10:49 am
Max4
SubscriberThe Execute Commands of the above picture used the range 0 3, I have take the wrong picture but the procedure is the same.
I know that the range is between 0 and 3 because I have already make the simulation. Thereby, I don´t want to use the function Auto Range. Moreover, I want to save Pictures with the same legende and it is not possible using the function Auto Range.
Is it possible to add the legende (unity and Name) without using Auto Range ?
Maxime
November 13, 2018 at 10:51 am
DrAmine
Ansys EmployeeYou just fix the range for all time to 0..3 instead of Auto-range. The legend will be then fixed to this range and won't change.
Please use the new Objects to create contours, display and store them.
November 13, 2018 at 10:59 am
Max4
SubscriberI don´t want to change the legend, just add the name and unity of what is displayed i.e. Velocity and m/s.
Maxime
November 13, 2018 at 11:21 am
seeta gunti
Ansys EmployeeYou can add titles through the following command
/dis set titles right-bottom "velocity (m/s)"
Seeta
November 13, 2018 at 11:23 am
Keyur Kanade
Ansys EmployeeUse interactive mode to display contours. When you display contours, they will be saved under objects. Then you can display these objects through TUI as /display/objects
Does this serve your purpose?
November 13, 2018 at 11:43 am
Max4
SubscriberThank you for your answers.
Maxime
2524
2066
1279
1096
459
