August 1, 2019 at 3:45 pm
kfouladi
SubscriberHello All,
I have problem using a DEFINE_EXECUTE_AT_END UDF. It seems not to do anything or at least it does not create the output file (edata.txt). I originally had this UDF as a DEFINE_ON_DEMAND, which worked fine. Any help would be appreciated.
This is what fluent writes at the end:
Registering UdfSource, ("Users/kfoul_000/Documents/…../gen.c")
Registering Udflib, ("Users/kfoul_000/Documents/…./dp0/FFF-1/Fluent/libudfxaa1")
Writing data to C:Userskfoul_000Documents....dp0FFF-1FluentFFF-1.1.ip ...
(1) I have defined 3 User-Defined Memory. (2) Please disregard the accuracy of the equation.
My UDF file is attached to the next post.
Kamran
kfouladi
Subscriber#include "udf.h"
DEFINE_EXECUTE_AT_END(gen)
Domain *d; /* declare domain pointer since it is not passed as an
argument to the DEFINE macro */
real temp = 293.15;
real dudx, dudy;
real rho = 1000.0;
real sum_e;
sum_e=0.;
Thread *t;
cell_t c;
d = Get_Domain(1); /* Get the domain using Fluent utility */
/*(location index 0) */
/* Loop over all cell threads in the domain */
thread_loop_c(t,d)
begin_c_loop(c,t)
dudx = C_U_G(c,t)[0];
dudy = C_U_G(c,t)[1];
C_UDMI(c,t,0) = 1.0/temp*(2*(pow(dudx,2) + pow(dvdy,2) ));
C_UDMI(c,t,1) = rho;
C_UDMI(c,t,2) = C_UDMI(c,t,0) + C_UDMI(c,t,1);
sum_e += C_UDMI(c,t,2) * C_VOLUME(c,t);
end_c_loop(c,t)
printf("Volume integral e: %gn", sum_e);
FILE *fp;
fp = fopen("edata.txt","w+");
fprintf(fp, "Volume integral e: %gn", sum_e);
fclose(fp);
fflush(stdout);
August 2, 2019 at 6:50 pm
Konstantine Kourbatski
Ansys Employee1) is the DEFINE_EXECUTE_AT_END executed? You have printf, is this message been printed?
2) since you are not specifying explicit path to the file, fluent is expected to open file in project_filesdp0FLUFluent, but if it's not there, do a quick search of your folders to check if it's been written in a different place
August 2, 2019 at 8:18 pm
kfouladi
SubscriberI am not sure DEFINE_EXECUTE_AT_END is executed. printf is not printed and I checked my computer and there is no "edata.txt" in any directory.
August 2, 2019 at 8:20 pm
Ansys Employeeis it properly hooked: User-Defined - Functions - Hooks
August 4, 2019 at 3:04 pm
Ansys EmployeeIs DEFINE_EXECUTE_AT_END executed at every iteration? Do you see printf outputs after each iteration? What may happen is the file is not overwritten at a subsequent execution, but this is a basic C programming question not related to ANSYS products
2688
2138
1355
1136
462
