Executing error of script generated from ANSYS Electronics Desktop
    • Abdou1
      i generate a simple script from 2D Extractor to initialize th mesh :
      Dim oAnsoftApp
      Dim oDesktop
      Dim oProject
      Dim oDesign
      Dim oEditor
      Dim oModule
      Set oAnsoftApp = CreateObject("Ansoft.ElectronicsDesktop")
      Set oDesktop = oAnsoftApp.GetAppDesktop()
      oDesktop.RestoreWindow
      Set oProject = oDesktop.SetActiveProject("cpw_gnd_gsg11")
      Set oDesign = oProject.SetActiveDesign("CPW__CP")
      Set oModule = oDesign.GetModule("AnalysisSetup")
      oModule.RevertSetupToInitial "Setup1"
      when i run it, i get this error :
      this object does not support this property or method: 'RevertSetupToInitial'
      error '800a01b6'
    • rtk
      Hello- The 'RevertSetupToInitial' property or method is meant for HFSS design. Not for 2D extractor. This works perfectly for HFSS.nnnRegards,n
    • mbeliaev
      also I recommend to switch to Python interface. It will be more intuitive and you can use Command Window to test featuresnn
