Discovery Import
Discovery Import
existing Hardware is adequate?
    • bogdan.ionescu
      I Have NVIDIA tesla K40 and NVIDIA Quadra M4000 with 8 GB Ram on my workstation. Is this adequate? How is each of the above components contribute to solution process?
      Is there documentation showing how to use the product?
    • Naresh Patre
      Hello bogdan
      • You can run Discovery Live compatibility utility and see if the graphics cards are compatible for running ANSYS Discovery Live.
      • Currently, use of dual graphics cards is not supported.
      • There are several videos in Knowledge base which will help you get started with Discovery Live.
    • bogdan.ionescu
      Here are the results after running the compatibility tool. Since I have two devices, how is this going to work with Discovery? Which one will be used?
      Thanks,
      Bogdan
      The Discovery Live Compatibility Checker results are as follows:
      All graphics devices are compatible with Discovery Live.
      GPU Information:
      GPU 1: NVIDIA Quadro M4000
      Driver version: 22.21.13.8248
      Driver date: June 2017
      GPU 2: NVIDIA Tesla K40c
      CUDA Version: 8
      CUDA Devices:
                  Device 1: Tesla K40c, RAM: 11.1788 GB
                  Device 2: Quadro M4000, RAM: 8 GB
      (CODE: PREREQ_0)
      • ERab
        bogdan Discovery Live will use 1 GPU for the solver and 1 for the graphics. It can be determined by its physical location in the PC or when you launch the product. Please review this post existing Hardware is adequate?
