Exitflag variable in APDL
    • antud
      Hello everyone,
      I'm doing a simulation of snap-through behaviour of a buckled beam/flexure. I am trying to obtain the force-deflection behaviour in both directions: from knee-up to knee-down and vice versa. In order to do this, I use a displacement-controlled analysis in the form of a loop. In this way, you're not required to set the target amount of displacement. The loop is as follows:
      *do,ii,1,#steps,1
      Increment displacement with 10 micron
      Evaluate reaction forces
      if(reaction forces < 10)
      continue
      else
      break loop
      end
      *enddo
      However, when not using the stabilize command, this gives some convergence errors.
      I was wondering whether it is possible to have the simulation return and store a variable upon divergence, something like an exitflag I can access when the simulation does not converge. Does anyone happen to know whether this is possible?
      Thank you in advance.
Viewing 0 reply threads
