Expand from Modal Solution
    • Autonewbie
      I am running a linear transient with modal. There are spring elements used and I got the following message that if the transient is expanded from modal solution, it is not possible to see any spring probe results... Does it mean I have to change it to transient solution or I can leave it to program controlled?
    • Erik Kostson
      HI
      I would try and run a full transient, not a transient based on modal superposition.
      All the best
      Erik
