June 3, 2023 at 11:19 am
June 5, 2023 at 7:22 pm
Guilin Sun
Ansys EmployeeYou are plotting the difference of reflection? or the far field?
Since this is difference, positive and negative are normal.
I would suggest that you use a local override to the vias with the largest height (0.1um from the figure) so to keep the mesh without change when the height changes. Make sure those heights have integer number of mesh size to preserve the interface the same.
June 12, 2023 at 3:02 pm
SAURAV GAUTAM
Subscriberthank you,
it's in farfield.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2961
1449
1322
