June 12, 2023 at 3:11 pm
June 12, 2023 at 6:09 pm
Guilin Sun
Ansys EmployeeIt might be due to PML reflection. Please increase the distance bwtween PML and the device, and the number of PML layers. It can also due to insufficient simulation/larger autoshutoff min. Please make sure it is the autoshutoff min (1e-5 by default) to terminate the simulation, eg, the simulation is terminated before reaching 100% progress.
I would suggest you to use override mesh for the pattern, and make sure the height is the integer number of the mesh so each time the interface is the same treatment.
June 17, 2023 at 6:13 am
SAURAV GAUTAM
Subscriberthank you,
i checked mesh and cut off setting but result is same. it seems the issue is because of diffraction effect.
June 18, 2023 at 2:19 pm
June 19, 2023 at 2:31 pm
Guilin Sun
Ansys EmployeeYou can using grating analysis to get transmission of a specific diffraction order: https://optics.ansys.com/hc/en-us/articles/360042088813-Diffraction-grating
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2957
1449
1322
