September 6, 2022 at 11:14 am
i.tamunodienye2
SubscriberHi All,
I am modeling multiphase flow (water-liquid and ideal gas). Is it appropriate to leave spartial discretization (density, momentum, TKE, SDR, energy and transient formulation) in first order when explicit scheme is selected. Surface tension and pressure forces acting on the bends of the structure are important.
Also, in the same multiphase flow modelling, is it appropriate to leave spartial discretization (density, momentum, TKE, SDR, transient formulation and energy) as second order when implicit formulation scheme is selected. Like above, surface tension and pressure forces are important.
Your help is much appreciated.
Regards
September 6, 2022 at 3:30 pm
Ansys EmployeeIdeally you want second order, what are the defaults? However, spatial (mesh) and temporal (time) resolution may be more critical: do NOT just rely on y+ to show the mesh is adequate.
Which model, and what are you actually simulating? The correct choice of multiphase model will far out weigh discretisation schemes.
September 6, 2022 at 3:40 pm
i.tamunodienye2
SubscriberHi Rob,
Thanks for your response.
I am simulating multiphase flow (ideal and water-liquid) in a pipe to analyse the forces at the bends as a result of flow induced vibration generated by the momentum of the two-phase flow. So pressure forces at the bends are important information i need. It is multiphase flow.
Thanks
September 6, 2022 at 3:45 pm
Ansys EmployeeWhich flow regime? Which multiphase model?
September 6, 2022 at 4:13 pm
i.tamunodienye2
SubscriberPredominantly slug flow regime
VOF multiphase model.
September 7, 2022 at 6:10 am
DrAmine
Ansys EmployeeExplicit formulation has nothing to do with the spatial discreization of other transportaed variables as the latter do not use any multi-time steps when advecting the equation. So try as much as possible to use Secon Order Accuracy Schemes.
September 7, 2022 at 9:03 am
Ansys EmployeeSo, as Amine says, ideally second order. Also read up on turbulence damping for VOF. You're going to need a small time step, well resolved mesh and patience for this.
September 7, 2022 at 10:52 am
i.tamunodienye2
SubscriberThank you Rob and Dr Amine.
September 7, 2022 at 11:07 am
DrAmine
Ansys EmployeeGood Luck!
2656
2116
1337
1118
461
